Operator and instruction manuals (2)
Showing 2 of 2 documents
Showing of 2 documents
Service manuals (1)
Showing 1 of 1 documents
Showing of 1 documents
Specifications
Input voltages 120-240 V, 1-PH, 50/60 Hz
Input current @ 4.1 kW 120-240 V, 1-PH, 24-20.5 A
Output current 15-33 A
Rated output voltage 125 VDC
Duty cycle @ 40°C (104°F)
35%, 240 V
20%, 120 V
Open circuit voltage (OCV) 256 VDC
Dimensions with handles 356 mm (14.0") D; 168 mm (6.6") W; 305 mm (12.0") H
Weight w/ 4,5 m (15') torch
CSA: 9.7 kg (21.4 lbs.)
CE: 9.5 kg (21 lbs.)
Gas Supply Clean, dry, oil-free air or nitrogen
Recommended gas inlet flow rate / pressure 113.3 l/min (4 scfm) at 80 psi (5.5 bar)
Input power cable length 3 m (10')
Power supply type Inverter - IGBT
Engine drive requirement 5.5 kW for full 33 A output
Certifications
CSA — certified for use in the Americas and Asia, except China
CE — for use in Europe and other countries where accepted.
Warranty Power supply: 6-year, Torch: 1-year
Greener Cuts logoEnvironmental stewardship is a core value of Hypertherm. Our Powermax products are engineered to meet and exceed global environmental regulations including the RoHS directive.
Replacement parts
For complete list of replacement parts, view the manual. Please contact an authorized Hypertherm distributor to place your parts order.
Exterior, front
Exterior, front of Powermax33 XP
Item
Kit number
Description
228096
Kit: Screws for the power supply cover and handle (not shown)
1
428219
Kit: Powermax30 XP Front panel
1
429298
Kit: Powermax33 XP front panel
2
428226
Kit: Current adjustment knob
3
428221
Kit: Powermax30 XP Power supply cover with labels, CSA
3
429296
Kit: Powermax33 XP cover with labels, CSA
3
428222
Kit: Power supply cover with labels, CSA, Built in America
3
428224
Kit: Powermax30 XP Power supply cover with labels, CE
3
429297
Kit: Powermax33 XP cover with labels, CE
3
428225
Kit: Power supply cover with labels, CCC
4
228099
Kit: Handle with screws
5
228561
Kit: Ground clamp
6
428239
Kit: Work lead, 4.6 m (15 feet), with ground clamp
Exterior, rear
Exterior, rear for Powermax30/33 XP
Item
Kit number
Description
1
428220
Kit: Rear panel
2
228210
Kit: CSA power cord with NEMA twist lock-style 240 V / 20 A plug, 1-phase, 3.0 m (10 feet)
3
229132
CSA power cord extension: 120 V / 15 A plug adapter
4
229133
CSA power cord extension: 240 V / 20 A plug adapter
5
228140
Kit: CE power cord, 1-phase, 3.0 m (10 feet) (plug not included)
5
428231
Kit: CCC power cord, 1-phase, 3.0 m (10 feet) (plug not included)
6
228143
Kit: Power cord strain relief
Interior, power board side
Interior, power board side for Powermax30/33 XP
Item
Kit number
Description
Designator
1
228104
Kit: Component barrier
2
428233
Kit: Power board, CSA (141304)
PCB2
2
428234
Kit: Power board, CE and CCC (141309)
PCB2
428411
Kit: Replacement hex nut standoffs (5) for mounting power board to heatsink (not shown)
Control board and power switch
Control board and power switch for Powermax30/33 XP
Item
Kit number
Description
Designator
1
428232
Kit: 30 XP Control board (141336)
PCB1
429300
Kit: 33 XP Control board (10087783)
2
428235
Kit: Power switch
S1
Interior, fan side
Interior, fan side
Item
Kit number
Description
Designator
1
228106
Kit: 30 XP Air filter/regulator with pressure switch
429295
Kit: 33 XP Air filter/regulator with pressure switch
2, 3
228095
Kit: Hoses: drain hose, two gas supply hoses, elbow fitting
3
428238
Kit: Replacement elbow fittings
4
428173
Kit: Solenoid valve
V1
5
428236
Kit: Fan assembly with plenum
M1
6
228103
Kit: Wire group: pressure switch wire pair, 3 ground wires
Air filter/regulator with pressure switch assembly
 Air filter/regulator with pressure switch assembly for Powermax30/33 XP
Item
Kit number
Description
228106
Kit: 30 XP Air filter/regulator with pressure switch assembly
429295
Kit: 33 XP Air filter/regulator with pressure switch assembly
1
428171
Kit: Air inlet fittings, CSA
2
428172
Kit: Air inlet fittings, CE/CCC
3
428237
Kit: Air filter element
4
428246
Kit: Air filter bowl
5
228688
Kit: Pressure switch
6
428262
Kit: Air filter retaining nut
Power supply base and magnetics
Power supply base and magnetics for Powermax30/33 XP
Item
Kit number
Description
1
228139
Kit: Plastic base
2
428230
Kit: Magnetics assembly
Duramax LT hand torch parts
Duramax LT hand torch for Powermax30/33 XP
You can replace the entire hand torch and lead assembly, or you can replace individual torch components.
Item
Kit number
Description
428174*
Kit: Duramax LT hand torch assembly with 4.6 m (15 foot) lead
1
228109
Kit: Torch cap-sensor switch
2
428162
Kit: Torch start switch
3
428178
Kit: Duramax LT torch body (includes O-ring)
4
428179
Kit: Replacement O-rings for torch body
5
428156
Kit: Torch trigger and spring
6
428182
Kit: Replacement springs for torch trigger
7
428177
Kit: Duramax LT torch handle (includes handle screws)
8
428181
Kit: Duramax LT torch replacement handle screws
9
428176
Kit: Duramax LT torch lead, 4.6 m (15 feet), with strain relief
* The torch assembly includes one set of general-purpose (standard) consumables:
  • Electrode (420120)
  • Swirl ring (420211)
  • Retaining cap (420114)
  • Nozzle (420118)
  • Shield (420116)
Accessories
Flip-up eye shades
The Hypertherm flip-up eye shades have shade 5 for plasma cutting up to 40 amps.
Read more
Plasma circle cutting guide
Plasma circle cutting guides cut circles up to 28″ in diameter.
Read more
System dust covers
Hypertherm system dust covers are made from a flame-retardant vinyl designed to protect your Powermax plasma cutting system from dust and dirt.
Read more
Technical support
