Abrasive waterjet pots
Operator and instruction manuals (23)
Abrasive regulator III - Instruction manual (Revision 3)
Last updated
06/02/2026
Part number: 809030
AccuValve on/off valve, A2 cutting head, and DiaLine cutting head - Instruction manual (Revision 0)
Last updated
05/15/2019
Part number: 810700
Showing 6 of 23 documents
Specifications
| Capacity | 6 cubic feet |
| Garnet capacity | 800 lbs (362.9 kg) |
| Operating control | 80 psi air |
| Net weight | 500 lbs (226.8 kg) |
| Length | 38 in (965.2 mm) |
| Width | 31 in (787.4 mm) |
| Height | 43.5 in (1104.9 mm) |
| Opening diameter | 24 in (609.6 mm) |
Field service bulletins (3)
PLC update: bleed-down valve operation for HyPrecision 15/30/50 waterjet pumps - Field service bulletin (Revision 0)
Last updated
05/20/2019
Part number: 809790
Valve lock kit for HyPrecision 50S/60S/75S waterjet pumps with redundant intensifiers - Field service bulletin (Revision 0)
Last updated
05/20/2019
Part number: 810270
Showing 3 of 3 documents
Technical support
| Resource center |
| Support by product |
| System support |
| Documents library |
| Training |
| FAQs |
| For educators |
| Tradeshows and events |
| Additional resources |
Useful links
Learn about Hypertherm's committment - Elimination, recycling, and reduction of waste is the foundation of a good approach to end-of-life equipment management. Determine the most sustainable path for your system.
