HyPrecision Predictive waterjet pumps (S series)
Operator and instruction manuals (2)
HyPrecision Predictive P-15/P-30/P-50/P-50S/P-60S/P-75S waterjet pump - Operator manual (Revision 0)
Last updated
02/04/2019
Part number: 810120
Redundant intensifier operation for HyPrecision Predictive waterjet pumps with redundant intensifiers - Operation guide (Revision 0)
Last updated
05/20/2019
Part number: 810690
Showing 2 of 2 documents
Specifications
View the product brochure under the Resources section for the full specifications.
| Pump model number | HyPrecision P-50S | HyPrecision P-60S | HyPrecision P-75S | |||||
| Hz | 50 | 60 | 50 | 60 | 50 | 60 | ||
| GENERAL | ||||||||
| Maximum output: gpm (lpm) | 1.0 (3.79) | 1.2 (4.54) | 1.5 (5.68) | |||||
| Maximum orifice: inch (mm) | 0.014 (0.35) | 0.016 (0.40) | 0.017 (0.43) | |||||
| PUMP POWER | ||||||||
| Motor Power: HP (kW) | 50 (37) | 60 (44.7) | 75 (56) | |||||
| Voltage | 400 | 208-230 | 460 | 400 | 460 | 400 | 460 | |
| Full load amps | 73.8 | 138.2-125.8 | 62.9 | 90.7 | 74.4 | 110.3 | 89.6 | |
| PHYSICAL | ||||||||
| Width | 40" (1016 mm) | |||||||
| Length | 79" (1996 mm) | |||||||
| Height | 59" (1509 mm) | |||||||
| Operating weight lbs. (kg) |
2,800 (1,300) |
3,200 (1,450) 3,400 (1,550) Redundant |
3,300 (1,500) 3,500 (1,600) Redundant |
Technical support
| Resource center |
| Support by product |
| System support |
| Documents library |
| Training |
| FAQs |
| For educators |
| Tradeshows and events |
| Additional resources |
Useful links
