DynaMAX 5100/5150 dual intensifier waterjet pumps
Operator and instruction manuals (1)
Showing 1 of 1 documents
Showing of 1 documents
Specifications
  DynaMAX 5100 DynaMAX 5150
  50 Hz 60 Hz 50 Hz 60 Hz
General
Maximum output flow 2.1 gpm (7.95 lpm) 2.2 gpm (8.33 lpm) 3.0 gpm (11.36 lpm) 3.2 gpm (12.11 lpm)
Maximum orifice 0.020" (0.508 mm) 0.021" (0.533 mm) 0.024" (0.610 mm) 0.025" (0.635 mm)
Continuous output pressure Adjustable to 60,000 psi (4137 bar)
Intensifier configuration Dual
Pressure control Electronic proportional
Bleed-down valve Hydraulic
Pump power
Motor Power 100hp (74.6 kW) 150hp (111.9 kW)
Voltage 400 V 460 V 400 V 460 V
Full load 138 A 117.5 A 204 A 173.4 A
Main breaker 150 A 225 A
Soft start True soft start
Physical
Overall width 45" (1143 mm) 55" (1397 mm)
Overall length 86" (2184 mm) 81" (2057 mm)
Overall height 56" (1422 mm) 56" (1422 mm)
Approximate operating weight 4150 lb (1882 kg) 6100 lb (2767 kg)
Options
External air-over-oil cooling Optional Optional
Chiller for oil cooling Optional Optional
Water isolation valves Optional Standard
Technical support
