HyPrecision 100D/150D waterjet pumps (D series)
Operator and instruction manuals (4)
Attenuator guard for 60-hp, 75-hp, 100-hp, 125-hp, and 150-hp pumps with redundant intensifiers - Installation guide (Revision 0)
Last updated
05/15/2019
Part number: 809640
HyPrecision 100D/150D waterjet pump - Instruction manual (Revision A)
Last updated
05/15/2019
Part number: 808310
PLC update 10304: automatic start procedure for HyPrecision 100D/150D and HyPrecision 50S/60S/75S waterjet pumps - Manual addendum (Revision 0)
Last updated
02/25/2020
Part number: 810650
Showing 4 of 4 documents
Specifications
HyPrecision 100D | HyPrecision 150D | |||
50 Hz | 60 Hz | 50 Hz | 60 Hz | |
General | ||||
Maximum output flow | 2.1 gpm (7.95 lpm) | 2.2 gpm (8.33 lpm) | 3.0 gpm (11.36 lpm) | 3.2 gpm (12.11 lpm) |
Maximum orifice | 0.020" (0.508 mm) | 0.021" (0.533 mm) | 0.024" (0.610 mm) | 0.025" (0.635 mm) |
Continuous output pressure | Adjustable to 60,000 psi (4137 bar) | |||
Intensifier configuration | Dual | |||
Pressure control | Electronic proportional | |||
Bleed-down valve | Hydraulic | |||
Pump power | ||||
Motor Power | 100hp (74.6 kW) | 150hp (111.9 kW) | ||
Voltage | 400 V | 460 V | 400 V | 460 V |
Full load | 138 A | 117.5 A | 204 A | 173.4 A |
Main breaker | 150 A | 225 A | ||
Soft start | True soft start | |||
Physical | ||||
Overall width | 45" (1143 mm) | 55" (1397 mm) | ||
Overall length | 86" (2184 mm) | 81" (2057 mm) | ||
Overall height | 56" (1422 mm) | 56" (1422 mm) | ||
Approximate operating weight | 4150 lb (1882 kg) | 6100 lb (2767 kg) | ||
Options | ||||
External air-over-oil cooling | ||||
Chiller for oil cooling | ||||
Water isolation valves |
Water and hydraulic isolation valves |
Orifice combinations supported by the HyPrecision pumps
HyPrecision 100D
Orifice size | in (mm) |
1 orifice | 0.020 (0.51) |
2 orifices | 0.014 (0.36) |
3 orifices | 0.011 (0.28) |
4 orifices | 0.010 (0.25) |
5 orifices | 0.009 (0.23) |
6 orifices | 0.008 (0.20) |
HyPrecision 150D
1 orifice | 0.024 (0.61) |
2 orifices | 0.017 (0.43) |
3 orifices | 0.014 (0.36) |
4 orifices | 0.012 (0.30) |
5 orifices | 0.011 (0.28) |
6 orifices | 0.010 (0.25) |
Nozzle and Orifice Combinations
Orifice | Nozzle | Abrasive (lb/min) | Abrasive mesh |
0.007 | 0.020 | 0.25 | 120 - 220 |
0.009 | 0.030 | .4 - .6 | 80 - 120 |
0.010 | 0.030 | .5 - .75 | 80 - 120 |
0.013 | 0.040 | 1.0 - 1.25 | 60 - 80 |
0.014 | 0.040 | 1.1 - 1.35 | 60 - 80 |
0.015 | 0.040 | 1.25 - 1.5 | 60 - 80 |
0.016 | 0.040 | 1.3 - 1.5 | 60 - 80 |
Typical combinations by pump size
HP | Qty heads | Orifice/Nozzle |
100 | 2 | .014/.040 |
100 | 4 | .010/.030 |
150 | 2 | .017/.045 |
150 | 3 | .014/.040 |
150 | 6 | .010/.030 |
Power vs. flow for HyPrecision waterjet pumps
Model | Power | Pressure | Max. output flow | Max. orifice size | ||||
hp | kW | psi | bar | GPM | L/min | in | mm | |
100D | 100 | 74 | 60,000 | 4137 | 2.10 | 7.95 | 0.020 | 0.51 |
150D | 150 | 110 | 60,000 | 4137 | 3.00 | 11.40 | 0.024 | 0.61 |
Field service bulletins (1)
Showing 1 of 1 documents
Technical support
Resource center |
Support by product |
System support |
Software updates and support |
Report counterfeit consumables |
Documents library |
Training |
FAQs |
For educators |
Tradeshows and events |
Additional resources |
Useful links
