Benefits
Easy to use
The single-piece color coded Powermax cartridge
consumable dramatically simplifies consumable identification
and installation for any cutting and gouging application. -
Installation of a torch adapter onto a Duramax, Duramax
Lock, or Duramax Hyamp torch makes conversion to the
cartridge platform a simple process. -
The Cartridge retrofit torch easily clicks into place on
Powermax systems, enabling use of the Powermax cartridge
without an adapter.
Cost Effective
- The Powermax cartridge reduces costly mistakes caused
by using the wrong consumable or not knowing which
consumable needs to be changed and when. - Cartridge performance is optimized for cut quality and
consumable life, and changing out cartridges is fast and
efficient. - Consumable inventory management is streamlined with
fewer parts to purchase and stock.
Compatible with adapters on Duramax, Duramax Lock®, and Duramax Hyamp torches
- Modernize legacy systems through Powermax cartridge by improving ease of use, versatility, and performance.
Full Powermax cartridge performance is achievable through use of adapter on Duramax, Duramax® Lock, and Duramax Hyamp torches (found on Powermax45 XP/65/85/105/125).
Requires separate torch adapter for Duramax and Duramax Lock (part number 428951) and For Duramax Hyamp (part number 528160)
Does not provide automated process set-up or data transfer
| System | Torch type | Part number |
Powermax45 XP Powermax85 Powermax105 |
Duramax and Duramax Lock hand, mechanized and robotic |
428951 |
| Powermax125 | Duramax Hyamp hand, mechanized, and robotic | 528160 |
- Not recommended for use on Duramax retrofit torches for Powermax1000/1250/1650
- The cartridge consumable platform is standard for the Powermax45/65/85/105 SYNC® systems with SmartSYNC® torches (no adapter required)
Compatible with Cartridge RT retrofit torches
Full Powermax cartridge performance is achievable through use of Cartridge HRT (hand) and MRT (machine) retrofit torches on legacy Powermax systems.
Cartridge RT retrofit torches install easily with a simple click on Powermax45 XP/65/85/105/125 systems.
Use of Powermax cartidge on Cartridge RT retrofit torches not provide automated process setup or access to cartridge performance data.
Part numbers for Cartridge RT torches are 059920 (hand 25'), 059930 (machine 50') and 059940 (mini-machine 50')
Powermax45 XP Powermax65 Powermax85 Powermax105 Powermax125 |
Cartridge HRT 75° hand torch w/7.6 m (25') lead | 059920 |
| Cartridge HRT 75° hand torch w/15.2 m (50') lead | 059921 | |
| Cartridge MRT 180° machine torch w/7.6 m (25') lead | 059928 | |
| Cartridge MRT 180° machine torch w/7.6 m (35') lead | 059929 | |
| Cartridge MRT 180° machine torch w/15.2 m (50') lead | 059930 | |
| Cartridge MRT 180° mini-machine torch w/7.6 m (25') lead | 059938 | |
| Cartridge MRT 180° mini-machine torch w/15.2 m (50') lead | 059940 |
Cartridge Adapter
Powermax cartridge adapters are designed to support several cartridge change-outs. Periodically inspect and remove the adapter from the torch to check for cracking and thread wear to determine when to replace.
The Hyamp adapter adds 1.31" (33 mm) to the operational length of the Duramax Hyamp torch.
Cartridge adapter for Powemax45 XP/65/85/105
The standard adapter adds .69" (18 mm) to the operational length of the Duramax and Duramax Lock torch.
Hypertherm cartridges part numbers
Hypertherm cartridges for Powermax systems are manufactured to uphold our high standards for quality and reliability. As part of the manufacturing process, we test-fire each cartridge to ensure proper assembly and function.
Drag cutting and FineCut for hand torches
Hypertherm cartridges |
Process |
Cartridge |
Hyamp |
105 A |
85 A |
65 A |
45 A |
30-45 A FineCut® hand cutting |
Drag cartridge:
FineCut cartridge:
HyPilot for mechanized cutting
Process |
HyPilot |
| Mechanized cutting 105 A | |
