Why accurate quoting matters more than ever for fabricators
Fabrication shops are built around keeping machines running, maintaining backlog, and winning new work. But the work that keeps a business healthy is not always the work with the highest volume. It is the work that is priced correctly, produced efficiently, and delivered with a return that supports the business.
That is getting harder to manage. Material costs change. Labor rates shift. Customers expect faster turnaround. At the same time, sales and estimating teams are often asked to respond to RFQs quickly using spreadsheets, manual calculations, and assumptions that may not reflect what will happen on the floor.
Quote Manager, a browser-based quoting solution for ProNest nesting software from Hypertherm Associates, helps close that gap. By connecting quoting activities with production data, fabricators can build more accurate estimates, respond faster, and have more confidence in the jobs they choose to take on.
When quoting is off, the problem does not stay in the estimate. A quote built on bad assumptions can lead to lower margins, schedule pressure, material waste, and difficult handoffs once the job reaches production.
The cost of getting quotes wrong and relying on spreadsheets alone
Every fabricator knows the risk on both sides of the quote. Price the job too high and someone else may win it. Price it too low and the shop may stay busy with work that does not deliver the expected margin.
The hard part is that quoting mistakes are not always obvious at the beginning. A spreadsheet may assume a certain nest yield, cutting time, setup requirement, or labor rate. If the final nest uses more material than expected or production takes longer than planned, the margin can shrink fast.
Spreadsheets are still useful. They are familiar, flexible, and easy to adjust. But as operations grow, it becomes harder to keep material prices, machine rates, labor assumptions, overhead, and costing formulas consistent across every quote.
For shops using Hypertherm plasma systems, OMAX waterjet systems, laser cutting equipment, or mixed-cutting environments supported by ProNest software, that consistency matters. The more complex the operation, the more important it is that quoting reflects how the work will actually be produced.
Connecting sales to production
Quote Manager helps connect sales and production by giving estimators access to quoting information tied to how the work will be cut. Instead of building a price from disconnected spreadsheets or outdated assumptions, teams can use production-based inputs from ProNest, including material utilization and machine time.
When that connection is missing, the handoff from sales to production can get messy. A job may be sold with assumptions about material yield, cutting time, secondary operations, or delivery dates that do not match the way the part will actually be manufactured.
That mismatch can show up later as margin pressure, schedule changes, rework, or difficult conversations between sales, estimating, and the shop floor. The issue is not that one team got it wrong. It is that each team was working from different information.
By bringing quoting closer to nesting and production data, Quote Manager helps reduce that gap. Estimators can move faster, while the quote stays grounded in the manufacturing details that affect cost, capacity, and profitability.
Faster quotes help win more business
Customers often send the same RFQ to more than one supplier. The shop that responds quickly with a professional, accurate quote has an advantage, but speed alone is not enough.
A fast quote built on weak assumptions can create problems later. The goal is to help estimators move quickly without forcing them to choose between turnaround time and confidence.
Whether a shop is cutting steel with a Hypertherm plasma system, producing precision components with an OMAX waterjet, or running a mixed-cutting operation supported by ProNest software, accurate pricing can directly affect win rates and profitability.
Modern quoting tools help make that possible by using existing production data and standardized costing rules, so estimators spend less time chasing information and more time evaluating the right opportunities.
Better visibility leads to better business decisions
Quoting data can tell a shop a lot about the health of the business, including win rates, lost opportunities, customer profitability, margin trends, and response times.
Without a centralized quoting process, that information may be scattered across spreadsheets, emails, shared drives, and individual workstations.
When quoting, nesting, and production information are part of a connected workflow, fabricators can see trends that disconnected systems often hide.
That visibility can support better decisions around pricing, capacity, sales strategy, and long-term growth.
How Quote Manager helps fabricators quote with confidence
Quote Manager is an optional browser-based module for ProNest nesting software. It helps fabricators create faster, more accurate quotes using the same production data that drives manufacturing operations, including material utilization, machine time, and other factors that influence cost and profitability.
Unlike generic estimating tools, Quote Manager was designed for fabrication environments where machine performance, nesting efficiency, and production costs directly affect margin. By using information already available inside ProNest, fabricators can base quotes on production-driven data instead of assumptions alone.
Quote Manager supports a quote-to-cut workflow by connecting estimating decisions with shop-floor requirements before a job reaches manufacturing. Because it is browser-based, sales and estimating teams can create, review, modify, and share quotes from desktop computers, laptops, tablets, and mobile devices on a company network. For manufacturers already using ProNest to support plasma, laser, oxyfuel, waterjet, and other cutting processes, Quote Manager extends that investment by adding consistency and visibility to the front end of the business. It also integrates with ProNest Production Manager for additional visibility into lead times and job status.
The bottom line
In fabrication, profitability is often determined before the first part is cut.
Accurate quoting helps fabricators protect margins, improve consistency, respond faster to customers, and keep sales aligned with production. As shops modernize, quoting is becoming less about disconnected spreadsheets and more about using production data to make better decisions.
For manufacturers using Hypertherm plasma technology, OMAX waterjet systems, or mixed-cutting operations supported by ProNest software, accurate quoting remains one of the most important ways to protect profitable growth.
Frequently asked questions
What is quoting software for fabricators?
Quoting software helps manufacturers estimate the cost of producing parts by accounting for variables such as material costs, machine time, labor, secondary operations, and overhead expenses. The goal is to create more accurate and consistent customer quotes.
Why is accurate quoting important in metal fabrication?
Accurate quoting helps fabricators balance competitiveness and profitability. Underestimating costs can reduce margins, while overpricing can result in lost opportunities.
How does Quote Manager work with ProNest?
Quote Manager is an optional browser-based module for ProNest. It uses nesting data and machine parameters from ProNest to help create quotes that reflect actual production conditions, including material utilization and machine time.
Can sales teams create quotes without having ProNest installed?
Yes, Quote Manager is browser-based and can be accessed through a browser on a company network using desktop computers, laptops, tablets, and mobile devices.
What are the benefits of connecting quoting to production data?
Connecting quoting to production data helps improve costing accuracy, reduce estimating guesswork, increase pricing consistency, and improve communication between sales and production teams.
Does Quote Manager support shops using multiple cutting technologies?
Quote Manager works alongside ProNest software, which supports a variety of cutting processes used throughout the fabrication industry. ProNest users can leverage production-based information to support a more accurate and consistent quoting process.
