Benefits
Significantly Improved Consumable Life in High-Pilot Applications
Customers whose applications require continuous or excessive
piloting face rapid consumable wear, frequent changeouts, and
rising operating costs. Increased pilot-arc time accelerates
nozzle bore erosion, leading to inconsistent cut quality,
increased downtime, and reduced throughput — especially in
automated or high-productivity environments..
Breakthrough NickelPlus Technology
The HyPilot cartridge with patent-pending NickelPlus
technology extends nozzle life up to six times that of standard
copper parts in high-pilot applications while maintaining
cut quality and productivity. The result is fewer consumable
changeouts, lower cost per cut, and more consistent output in
automated, robotic, and high-use hand cutting applications.
Key Features:
• 105 A mechanized cartridge engineered for demanding, high-pilot applications
• Silver-nickel nozzle bore designed to slow pilot-arc wear and extend durability
• Color-coded cartridge for fast, unmistakable visual identification
• Compatible with SmartSYNC® and Duramax® torches using the cartridge adapter
• 50-piece bulk pack option to streamline inventory and reduce handling
Applications Benefiting from HyPilot
3D heavy robotic and high-use cobot cast trimming
Automated and stand-off cutting of expanded metal/grating
Heavy-use hand (stand-off) cutting with moderate/excessive piloting
HyPilot Cartridge Options
| Process | Cartridge | 50-piece bulk kit | Ohmic ring kit |
| HyPilot mechanized cutting 105A | 528157 | 528158 | 428895 |
