Weld preparation
Read more
Patented HyAccess™ consumables extend approximately 76 mm (3″) beyond standard Powermax® consumables to provide the extra reach needed when cutting or gouging in hard to reach or confined spaces. HyAccess’s unique consumable design allows for better visibility and accessibility when working on challenging locations such as corners and channels.
HyAccess consumables are compatible with the following handheld torches and systems:
| System | Recommended amperage | Torch series |
Type of consumables |
| Powermax65/85/105 SYNC® | 15–65 A | SmartSYNC® | Hypertherm cartridges |
| 15–65 A | Duramax® |
| 15–65 A | Duramax Lock |
| 15–65 A | Duramax LT | Standard consumables | |
Powermax45® |
15–65 A | T45v | Standard consumables |
Powermax30® |
15–65 A | T30v | Standard consumables |
Powermax1000, Powermax1250, Powermax1650, Powermax600, Powermax800, Powermax900, MAX42, MAX 43 |
15–65 A | Duramax retrofit | Standard consumables |
Have a previous generation Powermax? No problem. Owners of our Powermax45 XP and Powermax65/85/105 can enjoy many of the benefits of our revolutionary cartridge consumable platform by simply adding a torch adapter to their current Duramax and Duramax Lock torch. The separate torch adapter will allow you to simplify consumable ordering, inventory, and installation by replacing your current 5-piece consumable stack-up with a Hypertherm cartridge. Learn more.
