Powermax30 AIR plasma cutter
Despite its small size, the Powermax30® AIR delivers big performance. This small air plasma cutter — the smallest, lightest handheld plasma cutter in its class — includes its own built-in air compressor. That's right, it's a small plasma cutter with a built-in compressor so you can use the Powermax30 AIR anywhere there’s single-phase power. Just plug it in, attach the work clamp and you’re ready to cut. It's even dual-voltage. You can use it as a 120 V plasma cutter or at 240 V. Regardless of which power input (120 V or 240 V) you choose, we think you'll agree the Powermax30 AIR is the best plasma cutter with built-in compressor available today.
System information
Applications
Drag cutting
Unsupported applications
Fine feature cutting
Try Powermax125
Max control gouging
Try Powermax125
Max removal gouging
Try Powermax125
Benefits
Easy to set up and operate
- Internal compressor eliminates the need for an external air compressor and filter
- Plug into any 120 or 240 V power (convenient Auto-Voltageâ„¢ technology and plug adapters included)
Superior performance in a compact package
- Patent-pending consumable design enables consistent cutting by optimizing the airflow from the compact, internal compressor
- Quickly cut metal grate or rusted metal without retriggering with the continuous pilot arc feature
- Fast cutting speeds and superior cut quality let you finish jobs quicker, with fewer secondary operations
Relative cut performance on mild steel (chart)
Exceptional versatility
- Just one tool is all you need to cut a variety of metal types and thicknesses
- Small size and light weight let you take the Powermax30 AIR to the work, rather than bringing the work to the system – an ideal solution for a wide range of cutting applications
- Built to withstand heavy-duty use in the most demanding environments
Specifications
Cut capacities
| Capacity | Thickness | Cut speed |
| Recommended |
8 mm (5/16") 10 mm (3/8") |
500 mm/min (20 ipm) 250 mm/min (10 ipm) |
| Severance | 16 mm (5/8") | 125 mm/min (5 ipm) |
Cutting with 120 V input power
The maximum recommended output of 20 A, the cut capacities are:
3 mm (10 gauge) at 762 mm/min (30 ipm)
6 mm (1/4") at 355 mm/min (14 ipm)
10 mm (3/8") at 125 mm/min (5 ipm)
SPECIFICATIONS - CSA (for use in the Americas and Asia, except China)
SPECIFICATIONS - CE (for use in Europe, Australia & New Zealand - RCM, Serbia, UK - UKCA, Ukraine, and other countries where accepted)
SPECIFICATIONS - CCC (for use in China)
| Input voltages | 120-240 V, 1-PH, 50/60 Hz |
| Input current @ 2.5 kW | 120-240 V, 1-PH, 29-15 A |
| Output current | 15-30 A |
| Rated output voltage | 83 VDC |
| Duty cycle @ 40°C (104°F) |
35%, 240 V 20%, 120 V |
| Open circuit voltage (OCV) | 256 VDC |
| Weight with 4,5 m (15') torch | 9.5 kg (21.8 lbs) |
General specifications:
| Dimensions with handles | 420 mm (16.5") D; 195 mm (7.7") W; 333 mm (13.1") H |
| Input power cable length | 3 m (10') |
| Power supply type | Inverter - IGBT |
| Engine drive requirement | 5.5 kW for full 30 A output |
| Electrical efficiency | 86% |
| Warranty | Power supply: 6-year, Torch:1-year |
Environmental stewardship is a core value of Hypertherm. Our Powermax products are engineered to meet and exceed global environmental regulations including the RoHS directive.
Buying information
ORDERING INFORMATION - CSA (For use in the Americas and Asia, except China)
Below are the standard system configurations, which include a power supply, torch, and work lead.
Duramax LT hand torch with 4,5 m (15′) lead and work clamp with 4,5 m (15′) lead |
Powermax30 AIR power supplies |
Handheld |
120-240 V CSA standard power supply |
088096 |
ORDERING INFORMATION - CE (For use in Europe, Australia & New Zealand - RCM, Serbia, UK - UKCA, Ukraine, and other countries where accepted.)
Handheld |
| 120-240 V CE standard power supply |
088098 |
ORDERING INFORMATION - CCC (for use in China)
Handheld |
| 120-240 V CCC standard power supply |
088103 |
