Discover the key differences that make a Powermax plasma cutter your most reliable choice
Mitigate downtime by selecting the most reliable tool for the job
If your shop has suffered downtime due to the failure of metal fabrication equipment, you likely understand the importance of using the best, most reliable tool for the job. When your shop experiences unplanned downtime, the production floor and productivity suffer. In the video, Harry Mellot, Project Manager, Business Team and Integrated Cutting Solutions Marketing, Hypertherm Associates, takes you through some key differences between a few competitive plasma cutters and Powermax models, showing why they are the most reliable choice to keep your jobs on time and budget.
Powermax: the most versatile and reliable family of plasma cutters on the market
Hypertherm Associates®, an Associate-owned company, takes great care in designing, building, and testing the most robust plasma cutters for the professional metal worker. The Powermax product line consists of seven systems that offer the greatest application versatility, ease of use, and reliability in the market. Powermax provides the widest variety of plasma cartridges and torch options available, so you can excel in your job by expanding your cutting and gouging capabilities.
This versatility of application capabilities distinguishes Powermax from any other plasma system on the market.
Comparing the design of the new Powermax45 SYNC versus two competitors
Powermax45 SYNC ― designed for cut quality and longevity:
Several considerations went into the design of the Powermax45 SYNC® to ensure system longevity. For example, the design separates the clean and dirty sides, preventing dust and debris from getting to the sensitive electronic components. All PC boards in Powermax systems are conformal coated for protection. A fan in the center of the heat sink evenly distributes cool air across the board to extend component life.
The Powermax45 SYNC was designed with as few components and connections as possible, significantly reducing potential failure points. Selected materials, from plastics and lead material to electronics and consumables, are tested for robustness and longevity and made or sourced from suppliers that meet the highest quality standards.
Powermax45 SYNC highlighted product features:
Easy to use
A patented single-piece cartridge eliminates operator error and simplifies operations
Advanced torch communication for automated setup improves cut quality
Easy to set up for mechanized usage with optional CNC interface and FastConnect™ torch connection
Versatile
Gain greater cutting power than higher-amperage competitors
Expand application capabilities with a wide variety of specialty cartridges and torches
Cut and mark using the same FineCut® cartridge
Industry-leading reliability
Powermax plasma cutters are known to last decades in the field, minimizing maintenance and downtime
SmartSYNC® torches are engineered for rugged industrial environments
Each Powermax component is tested to perform reliably in demanding conditions
Two competitors compared ― lower cost vs. high performance:
In comparing two competitive models, it’s evident they aren’t designed for longevity or robustness. For example, there’s no dust mitigation, the layout is poor, with the wiring and hoses going everywhere, and there are many loose connections. The components and materials in these models are of lower quality and likely picked for lower cost rather than high performance. These models and many more like them aren’t the best choice for someone who relies on their plasma cutter daily for their job.
The best investment is in your power
When selecting a plasma cutter for the job, choose wisely. Powermax is the world’s most versatile family of portable plasma cutters, delivering maximum productivity and unmatched reliability. With the industry’s most extensive handheld and automated cutting, marking, and gouging capabilities, customers can confidently tackle any job with superior cut quality and minimized secondary operations―at a lower total cost of ownership.
Now, with a 6-year power supply warranty. Best warranty. Best investment.
