Farming and ranching
Repairing and maintaining equipment, vehicles, and buildings is a frequent chore on farms and ranches of all sizes. The versatility of Hypertherm solutions makes this work quick, safe, and easy.
Maximize productivity anywhere you need to work
Hypertherm Powermax® air plasma systems are ideal for cutting iron, mild steel, stainless steel, and other conductive metals. Painted or rusted materials are also no problem, and the superior cut quality minimizes the need for time-consuming grinding and other secondary operations prior to welding.
Typical uses include:
Maintenance of trucks, tractors and other farm vehicles
Manufacture and repair of combine harvesters, balers, and other equipment
Repair and assembly of chemical or irrigation sprayers
Repair and maintenance of fencing, silos, and outbuildings
Fast, easy removal of old welds thorough the use of plasma gouging
Explore farming and ranching solutions
Plasma gouging
Plasma gouging – removing metal using a plasma arc – is similar to plasma cutting. A plasma arc between the torch and the workpiece melts the metal, and a gas jet blows away the molten material.
Extended reach cutting
Hypertherm’s HyAccess® extended reach consumables give users extra reach when plasma cutting or gouging in hard to access or confined spaces, and are designed for use with Powermax air plasma systems.
Plasma flush cutting
FlushCut® consumables for Powermax® systems allow easy removal of protrusions, welded attachments, bolts, and fixtures from metal surfaces without cutting into the base material.
