Choosing the right pump size for your waterjet system
By Hypertherm
Posted on 02/02/2017 in SPARK the blog, Waterjet cutting
When it comes to waterjet pumps, bigger isn't always better. Let's take a look at the advantages and disadvantages of two different sized pumps: 60,000 psi vs. 90,000 psi.
Advantages of a larger pump (90,000 psi):
  • Can cut thicker (more than 4") material
  • Can cut at a higher cut speed
  • Uses less abrasive
Disadvantages of a larger pump (90,000 psi):
  • Costs more to own and maintain
  • Higher downtime and shorter time between maintenance intervals because parts will wear out faster
Advantages of a smaller pump (60,000 psi):
  • Lower total cost of ownership
  • In many cases, a smaller pump can match the cut speed of a larger pump
  • Higher reliability
  • Longer time between service intervals
To summarize then, a larger pump may enable you to cut thicker material and at a higher cut speed, but you'll experience a higher operating cost and more downtime compared to a smaller pump.
Learn about Hypertherm Associates' DynaMAX waterjet pumps >
Search
Categories
Popular tags
