HPR cartridge for HPRXD systems
The Hypertherm HPR® cartridge represents a revolutionary change to traditional mechanized plasma consumables. Dramatically simplifying plasma cutting, the cartridge replaces five standard consumables, eliminating costly stack-up errors. Increase productivity with faster consumable changeover and reduced training time.
Benefits of HPR cartridge
Simplify plasma cutting
  • One cartridge replaces five standard consumables.
  • Toolless consumable change allows the cartridge to be replaced without removing the torch.
  • Clearly marked single-piece consumable eliminates stack-up errors.
  • Easy to upgrade - no process changes needed.
Lower operating cost
  • Longer life resulting in fewer consumables used.
  • Less time spent managing consumables at the cutting machine and reduces costs associated with purchase, inventory, and storage of consumables.
  • Improved quality over life reduces secondary operations, specifically grinding due to dross and angularity.
Enhanced cut quality
  • Extended cut quality over life compared to standard HPR consumables.
  • New consumables with each cartridge ensure the highest cut quality results from your HPR.
  • Fewer consumable parts to manage encourages customers to cut at recommended amperages for their applications.
Increased productivity
  • Faster consumable changeovers reduces downtime, putting more plate through cutting process.
  • Eliminates consumable stack-up mistakes that results in expensive rework, plate damage, torch and consumable failures, and down-time.
  • Simplifies operator training.
Simplified torch design with plug-in-play compatibility
  • Connects directly to standard HPRXD® receptable.
  • No setting changes required.
  • Use your current HPRXD torch for cutting all other HPR processes.
Request a demo
optional
View privacy policy
We would like to send you occasional information about our products, services and events. Select your preference below to tell us if you want to be kept up-to-date. You can unsubscribe at any time.
This site is protected by reCAPTCHA and the Google Privacy Policy and Terms of Service apply.
Learn more about the HPR cartridge
HPR cartridge part numbers
HPR cartridge
HPR cartridge consumablesNew!
Mild steel process Retaining cap Cartridge Water tube Torch body
80 A (standard cutting)* 420708 420803 420728 420729
130 A (standard cutting)* 420708 420705 420728 420729
260 A (standard cutting / bevel cutting)* 420708 420715 420728 420729
* HPR cartridge require a new torch body, water tube, and retaining cap. The HPR cartridge torch body connects directly to a standard HPRXD receptacle (part number 220705).
HPR cartridge kitsNew!
Type Kit p/n Includes p/n Description Quantity
Torch starter kit 528101 420729  Torch body 1
    420728 Water tube 1
    420708 Retaining cap 1
    528107 Kit: O-ring cartridge torch 1
Cartridge 3-pk kits
528102 420803 Kit: Cartridge, 80 A 3
  528103
420705
Kit: Cartridge, 130 A 3
  528104 420715 Kit: Cartridge, 260 A 3
   528105** 420803, 420705, 420715 Kit: Cartridge, multi-amps 3
** Note: 528105 cartridge multi-amps kit contains (1) of each amperage (80 A, 130 A, and 260 A).
Cartridge compatible HPRXD systems
