Quick-disconnect torch
The Centricut quick-disconnect torch incorporates proven Hypertherm torch technologies bringing you excellent performance and reliability.
- Quick-disconnect torch technology enables rapid job change-over increasing productivity.
- Detachable torch head makes changing consumables quick and easy.
- Optimized gas and coolant flow through the torch maximizes performance and reliability.
Advance to a better cutting experience with the Centricut quick-disconnect torch upgrade kit for your Kaliburn cutting system today.
Centricut torch features:
- Designed with engineering materials proven by Hypertherm for optimal torch performance while reducing the cost.
- Coupler ring designed to give a better grip when attaching torch head to base.
- Dust seals prevent metal chips and other debris from collecting in the coupler threads.
- Centricut torch components and consumables are fully compatible with OEM.
