The Centricut® swirl-ring removal tool (part number C23-001) can help you save hundreds of dollars each year in swirl ring cost. Many customers struggle to remove the swirl-ring from the nozzle after cutting. As a result, they will discard a perfectly good swirl-ring with the used nozzle. With the Centricut swirl-ring removal tool, operators can quickly and easily remove swirl rings from used nozzles and reuse them over and over.
Centricut swirl ring removal tool for Kjellberg and Kaliburn
