SureCut technology
SureCut™ technology helps maximize performance by providing embedded expertise through a combination of products that includes plasma power supplies and waterjet pumps, as well as CNCs and CAM software.
SureCut benefits:
- Automatically applies optimized cutting process parameters which simplifies cutting and reduces operator intervention
- Easy set up improves job efficiency
- Provides access to Remote Help™ and troubleshooting which reduces downtime
- Works across multiple cutting technologies
SureCut technology includes:
- True Hole® technology - applies process expertise to automatically deliver bolt ready holes
- True Bevel™ technology - automatically applies the correct bevel angle and reduces operator trial and error
- Rapid Part™ technology - increases the number of parts produced per hour by automatically reducing cut-to-cut cycle time between parts
- Sampled arc voltage CNC setting - improves consumables life by automatically maintaining torch height
How do these products work together?
Hypertherm Components
When using the XPR, EDGE Connect and ProNest together, SureCut benefits include: True Hole®, True Bevel™, Rapid Part™ and on CNC nesting benefits through ProNest CNC.
When using the XPR and EDGE Connect together, SureCut benefits include: Rapid Part™ and on CNC nesting benefits such as True Hole® in simple shapes with ProNest CNC.
When using the XPR and ProNest together from a licensed Channel Partner, SureCut benefits include: True Hole®, True Bevel™, Rapid Part™ and many more offline CAM software benefits.
When using the XPR from a licensed Channel Partner, SureCut benefits include: True Hole® and True Bevel™.
When using the EDGE Connect and ProNest together, SureCut benefits include: Rapid Part™, optimal spacing, optimal lead-ins and on CNC nesting benefits through ProNest CNC.
When using the EDGE Connect, SureCut benefits include: Rapid Part™, and on CNC nesting benefits through ProNest CNC.
When using ProNest, SureCut benefits include: Rapid Part™, optimal spacing, optimal lead-ins and many more offline CAM software benefits.
