SureCut technology
SureCut™ technology helps maximize performance by providing embedded expertise through a combination of products that includes plasma power supplies, as well as CNCs and CAM software.
SureCut benefits:
Automatically applies optimized cutting process parameters which simplifies cutting and reduces operator intervention
Easy set up improves job efficiency
Works across multiple cutting technologies
SureCut technology includes:
True Hole® technology - applies process expertise to automatically deliver bolt ready holes
True Bevel™ technology - automatically applies the correct bevel angle and reduces operator trial and error
Rapid Part™ technology - increases the number of parts produced per hour by automatically reducing cut-to-cut cycle time between parts
PlateSaver™ technology - combines XPR™ arc stability and specialized software parameters to dramatically increase material utilization
More profit per plate
New PlateSaverâ„¢ technology for XPRâ„¢ plasma cutting systems provides an impressive increase in material utilization, reducing waste and adding directly to your bottom line.
How do these products work together?
Hypertherm Components
When using the XPR, EDGE Connect and ProNest together, SureCut benefits include: True Hole®, True Bevel™, Rapid Part™, PlateSaver™, and on CNC nesting benefits through ProNest CNC.
When using the XPR and EDGE Connect together, SureCut benefits include: Rapid Part™ and on CNC nesting benefits such as True Hole® in simple shapes with ProNest CNC.
When using the XPR and ProNest together from a licensed Channel Partner, SureCut benefits include: True Hole®, True Bevel™, Rapid Part™, and many more offline CAM software benefits.
When using the XPR from a licensed Channel Partner, SureCut benefits include: True Hole® and True Bevel™.
When using the EDGE Connect and ProNest together, SureCut benefits include: Rapid Part™, optimal spacing, optimal lead-ins and on CNC nesting benefits through ProNest CNC.
When using the EDGE Connect, SureCut benefits include: Rapid Part™, and on CNC nesting benefits through ProNest CNC.
When using ProNest, SureCut benefits include: Rapid Part™, optimal spacing, optimal lead-ins and many more offline CAM software benefits.
