HyPrecision waterjet system comparison
The comparison chart below will help you choose the HyPrecision® system that will best meet the needs of your waterjet cutting application.
Technical data
HyPrecision 15 | HyPrecision 30 | HyPrecision 50 | HyPrecision 50S | HyPrecision 60S | HyPrecision 75S | HyPrecision 100D | HyPrecision 150D | |||||||||||
50 Hz | 60 Hz | 50 Hz | 60 Hz | 50 Hz | 60 Hz | 50 Hz | 60 Hz | 50 Hz | 60 Hz | 50 Hz | 60 Hz | 50 Hz | 60 Hz | 50 Hz | 60 Hz | |||
Maximum output flow | 0.30 gpm (1.14 lpm) |
0.60 gpm (2.27 lpm) |
1.0 gpm (3.79 lpm) |
1.1 gpm (4.16 lpm) |
1.2 gpm (4.54 lpm) |
1.3 gpm (4.92 lpm) |
1.5 gpm (5.68 lpm) |
1.6 gpm (6.06 lpm) |
2.1 gpm (7.95 lpm) |
2.2 gpm (8.33 lpm) |
3.0 gpm (11.36 lpm) |
3.2 gpm (12.11 lpm) |
Maximum orifice | 0.007" (0.178 mm) |
0.011" (0.279 mm) |
0.014" (0.356 mm) |
0.014" (0.356 mm) |
0.015" (0.38 mm) |
0.016" (0.406 mm) | 0.017" (0.432 mm) |
0.018" (0.457 mm) |
0.020" (0.508 mm) |
0.021" (0.533 mm) |
0.024" (0.610 mm) |
0.025" (0.635 mm) |
Continuous output pressure | Adjustable to 60,000 psi (4137 bar) | Adjustable to 60,000 psi (4137 bar) | Adjustable to 60,000 psi (4137 bar) | |||||||||||||||
Intensifier configuration | Single | Single | Dual | |||||||||||||||
Pressure control | Dual manual | Panel-mounted dual manual | Electronic Proportional | |||||||||||||||
Bleed-down valve | Air | Hydraulic | Hydraulic | |||||||||||||||
Motor Power | 15hp (11.2 kW) |
30hp (22.4 kW) |
50hp (37.3 kW) |
50hp (37.3 kW) |
60hp (44.7 kW) |
75hp (56 kW) |
100hp (74.6 kW) |
150hp (111.9 kW) |
Voltage | 400 V | 208-230/460 V | 400 V | 208-230/460 V | 400 V | 208-230/460 V | 400 V | 208-230/460 V | 400 V | 460 V | 400 V | 460 V | 400 V | 460 V | 400 V | 460 V | ||
Full load | 24 A | 43-39/19 A | 44 A | 83-75/38 A | 73 A | 135-122/61 A | 73 A | 138-125/62 A | 75 A | 71.1 A | 103 A | 87.1 A | 138 A | 117.5 A | 204 A | 173.4 A | ||
Main breaker | 25 A | 50/25 A | 50 A | 100 / 50 A | 100 A | 175 / 100 A | 80 A | 150 / 80 A | 100 A | 125 A | 100 A | 150 A | 225 A | |||||
Soft start | - | - | Wye-Delta | True Soft Start | True Soft Start | |||||||||||||
Overall width | 34" (864 mm) | 40" (1016 mm) | 45" (1143 mm) | 55" (1397 mm) | ||||||||||||||
Overall length | 70" (1778 mm) | 76" (1930 mm) | 86" (2184 mm) | 81" (2057 mm) | ||||||||||||||
Overall height | 46" (1168 mm) | 56" (1422 mm) | 56" (1422 mm) | 56" (1422 mm) | ||||||||||||||
Approximate operating weight | 2900 lb (1315 kg) | 3100 lb (1406 kg) | 3300 lb (1497 kg) | 4150 lb (1882 kg) | 6100 lb (2767 kg) | |||||||||||||
External air-over-oil cooling | External air-over-oil cooling | External air-over-oil cooling | ||||||||||||||||
Chiller for oil cooling | Chiller for oil cooling | Chiller for oil cooling | ||||||||||||||||
Water modulating valve | Redundancy | Water isolation valves | Water and hydraulic isolation valves | |||||||||||||||
External boost pump | Redundancy ready | - | ||||||||||||||||
- | Electronic proportional pressure control | - |
