Waterjet system comparison
The comparison chart below will help you choose the system that will best meet the needs of your waterjet cutting application.
DynaMAX 315
DynaMAX 315
(50/60 Hz)
DynaMAX 330
DynaMAX 330
(50/60 Hz)
DynaMAX 350
DynaMAX 350
(50/60 Hz)
DynaMAX 550P
DynaMAX 550P
(50/60 Hz)
DynaMAX 560P
DynaMAX 560P
(50/60 Hz)
DynaMAX 575P
DynaMAX 575P
(50/60 Hz)
DynaMAX 5100
DynaMAX 5100
(50/60 Hz)
DynaMAX 5150
DynaMAX 5150
(50/60 Hz)
Key specifications
Supported applications Water-only, abrasive Water-only, abrasive Water-only, abrasive Water-only, abrasive Water-only, abrasive Water-only, abrasive Water-only, abrasive Water-only, abrasive
Cut processes Waterjet Waterjet Waterjet Waterjet Waterjet Waterjet Waterjet Waterjet
Motor power 11.2 kW (15 HP) 22.4 kW (30 HP) 37.3 kW (50 HP) 37.3 kW (50 HP) 44.7 kW (60 HP) 57 kW (75 HP) 74.6 kW (100 HP) 111.9 kW (150 HP)
Intensifier type Single Single Single Single; Redundant Single; Redundant Single; Redundant Dual Dual
Voltage 208 - 230 V / 400 V / 460 V 208 - 230 V / 400 V / 460 V 208 - 230 V / 400 V / 460 V 208 - 230 V / 400 V / 460 V 400 V / 460 V 400 V / 460 V 400 V / 460 V 400 V / 460 V
Max. current draw 45 - 41 A / 23 A / 21 A 82 - 76 A / 44 A / 38 A 136 - 124 A / 74 A / 62 A 138 - 126 A / 74 A / 63 A 91 A / 74 A 110 A / 90 A 138 A / 118 A 204 A / 173 A
Max. pressure 4,100 bar (60,000 psi) 4,100 bar (60,000 psi) 4,100 bar (60,000 psi) 4,100 bar (60,000 psi) 4,100 bar (60,000 psi) 4,100 bar (60,000 psi) 4,100 bar (60,000 psi) 4,100 bar (60,000 psi)
Max. orifice size 0.18 mm (0.007″) 0.28 mm (0.011″) 0.35 mm (0.014″) 0.35 mm (0.014″) 0.40 mm (0.016″) 0.43 mm (0.017″) 0.51 mm (0.020″) 0.61 mm (0.024″)
Max. flow (high-pressure) 1.1 lpm (0.3 gpm) 2.3 lpm (0.6 gpm) 3.8 lpm (1.0 gpm) 3.8 lpm (1.0 gpm) 4.5 lpm (1.2 gpm) 5.7 lpm (1.5 gpm) 8.0 lpm (2.1 gpm) 11.4 lpm (3.0 gpm)
Product width 1,090 mm (43″) 1,090 mm (43″) 1,090 mm (43″) 1,020 mm (40″) 1,020 mm (40″) 1,020 mm (40″) 1,143 mm (45″) 1,397 mm (55″)
Product length 1,350 mm (53″) 1,350 mm (53″) 1,350 mm (53″) 2,000 mm (79″) 2,000 mm (79″) 2,000 mm (79″) 2,184 mm (86″) 2,057 mm (81″)
Product height 1,010 mm (40″) 1,010 mm (40″) 1,510 mm (59″) 1,510 mm (59″) 1,510 mm (59″) 1,010 mm (40″) 1,422 mm (56″) 1,422 mm (56″)
Approximate weight 775 kg (1,700 lbs) 825 kg (1,850 lbs) 925 kg (2,050 lbs) 1,300 kg (2,800 lbs) 1,450 kg (3,200 lbs) 1,500 kg (3,300 lbs) 1,882 kg (4,150 lbs) 2,767 kg (6,100 lbs)
  Learn more  Learn more  Learn more  Learn more  Learn more  Learn more  Learn more  Learn more
