Torch height control comparison
Sensor THC
Sensor® torch height control (THC)
ArcGlide THC
ArcGlide® torch height control
Sensor PHC
Sensor® torch height control (PHC)
Key specifications
SureCut™ compatible
True Bevel™
True Hole®
Rapid Part™
Cut processes
Plasma
(light industrial/conventional air/oxygen)
Plasma
(heavy industrial/high definition)
Plasma
Plasma
Plasma
Table types
Downdraft; Water table
Downdraft
Lifter stroke  239 mm (9.4″) 239 mm (9.4″) 152 mm (6″)
Max speed 15240 mm/min (600 ipm) 15240 mm/min (600 ipm) 5120 mm/m (200 ipm)
Weight capacity 11.4 kg (25 lbs) 11.4 kg (25 lbs) 4.5 kg (10 lbs)
Communication protocol
Discrete wiring to lifter I/O
Communication is based on the motor end drive selection. For EDGE Connect, choose an EtherCAT manufacturer from our approved vendor list.
 Discrete, RS-422 serial, or EtherCat to the HPR® / XPR™ plasma system
With Hypernet® – Hypernet® to the CNC/HMI or discrete to the plasma
Without Hypernet® - Hypernet® to the HMI or RS-422 serial to the CNC with discrete to the plasma
Discrete wiring to CNC and plasma
Breakaway type Magnetic or pneumatic Magnetic or pneumatic Magnetic
Torch clamp sizes
35 mm (1-3/8 in.): Powermax®
44 mm (1-3/4 in.): HSD130™ (standard), HT2000®, MAX200®, MAXPRO200®, Powermax125®
51 mm (2 in.): HPRXD®, HPR®, HT2000®, MAX200®, MAXPRO200®
57 mm (2-1/4 in.): XPR™
35 mm (1-3/8 in.) Powermax®
51 mm (2 in.): HT2000®, MAX200®, MAXPRO200®
  Learn more   Learn more   Learn more
