Powermax system comparison
There’s a portable Powermax® system that’s right for just about any cutting job you can throw at it. To make the best choice, compare them.
Powermax30 AIR
Powermax30® AIR plasma system
Powermax30 XP
Powermax30® XP plasma system
Powermax45 XP
Powermax45® XP plasma system
Powermax65
Powermax65® plasma system
Powermax85
Powermax85® plasma system
Powermax105
Powermax105® plasma system
Powermax125
Powermax125® plasma system
Key specifications
Supported applications Drag cutting
Drag cutting
Extended reach cutting and gouging
Fine feature cutting
Drag cutting
Flush cutting
Max control gouging
Max removal gouging
Marking
Mechanized cutting
Precision gouging
Drag cutting
Flush cutting
Max control gouging
Max removal gouging
Mechanized cutting
Drag cutting
Flush cutting
Max control gouging
Max removal gouging
Mechanized cutting
Drag cutting
Flush cutting
Max control gouging
Max removal gouging
Mechanized cutting
Drag cutting
Flush cutting
Max control gouging
Max removal gouging
Mechanized cutting
Cut processes Plasma - conventional air Plasma - conventional air Plasma - conventional air Plasma - conventional air Plasma - conventional air Plasma - conventional air Plasma - conventional air
Output amperage range 15 – 30 A 15 – 30 A 10 – 45 A 20 – 65 A 25 – 85 A 30 – 105 A 30 – 125 A
Recommended cut capacity   8 mm (5/16″) 10 mm (3/8″) 16 mm (5/8″) 20 mm (3/4″) 25 mm (1″) 32 mm (1-1/4″) 38 mm (1-1/2″)
Severance cut capacity   16 mm (5/8″) 16 mm (5/8″) 29 mm (1-1/8″) 32 mm (1-1/4″) 38 mm (1-1/2″) 50 mm (2″) 57 mm (2-1/4″)
Mechanized pierce capacity 12 mm (1/2″) 12 mm (1/2″) 16 mm (5/8″) 20 mm (3/4″) 25 mm (1″)
ISO 1913 cut range 5 5 5 5 5 5 5
Input voltage(s)
CSA 120 – 240 V, 1-PH, 50/60 Hz
CE 120 – 240 V, 1-PH, 50/60Hz
CE 120 – 240 V, 1-PH, 50/60 Hz
CCC 120 – 240 V, 1-PH, 50/60 Hz
CSA 200 – 240 V, 1-PH, 50/60 Hz
CSA 480 V, 3-PH, 50/60 Hz
CE/CCC 230 V, 1-PH, 50/60 Hz
CE/CCC 400 V, 3-PH, 50/60 Hz
CSA 200 – 480 V, 1-PH, 50/60 Hz
CSA 200 – 600 V, 3-PH, 50/60 Hz
CE/CCC 380 – 400 V, 3-PH, 50/60 Hz
CE 230 – 400 V, 3-PH, 50/60 Hz
CSA 600 V, 3-PH, 50/60 Hz
CE 400 V, 3-PH, 50/60 Hz
CCC 380 V, 3-PH, 50/60 Hz
kW output 2.49 3.8 6.5 9 12.2 16.8 21.9
Duty cycle at max current* 35% 35% 50% 50% 60% 80% 100%
Process/shield gas options Internal compressed air Air, N2, F5 Air, N2, F5 Air, N2, F5 Air, N2, F5 Air, N2, F5 Air, N2, F5
Torch style options Handheld torch Handheld torch
Handheld torches
Machine torches
Robotic torches
Handheld long torches
Handheld torches
Machine torches
Robotic torches
Handheld torches
Machine torches
Robotic torches
Handheld torches
Machine torches
Robotic torches
Handheld torches
Machine torches
Robotic torches
Product width 195 mm (7.7″) 140 mm (5.5″) 173 mm (6.8″) 234 mm (9.2″) 234 mm (9.2″) 274 mm (10.8″) 274 mm (10.8″)
Product height 333 mm (13.1″) 305 mm (12.0″) 356 mm (14.0″) 455 mm (17.9″) 455 mm (17.9″) 508 mm (20.0″) 508 mm (20.0″)
Product depth 420 mm (16.5″) 356 mm (14.0″) 442 mm (17.4″) 500 mm (19.7″) 500 mm (19.7″) 592 mm (23.3″) 592 mm (23.3″)
Approximate weight without torch and leads 13.5 kg (29.8 lb)** 9.7 kg (21.4 lb)** 12 kg (26 lb) 24.5 kg (54 lb) 27.2 kg (60 lb) 40 kg (88 lb) 41 kg (90 lb)
  Learn more  Learn more  Learn more  Learn more  Learn more  Learn more  Learn more
 * @ 40° C (104° F)
** includes torch and lead
CSA models are for use in the Americas and Asia, except China.
CE models are for use in countries that require CE or GOST marks.
CCC models are for use in China.
