HT4001 is a 340-amp water-injection plasma arc cutting system. It is the ideal combination of quality, productivity and flexibility. It’s a powerful, flexible system designed for high volume production applications where reliability is vital.
Produtos relacionados
Links relacionados
- 340-amp oxygen capability pierces and cuts mild steel up to 1-1/4 inch (32 mm) at 90, approximately 3/4-inch at 45 bevel
- LongLife™ oxygen technology reduces costs
- 400-amp base system expandable to 760 amps
Saiba mais
- Brochura do produto Inglês
- Manual do Operador Inglês
| Capacity Mild Steel |
Dross free Production (pierce) Severence (edge starts) |
32 mm (1-1/4")
32 mm (1-1⁄4") 75 mm (3") |
| Stainless Steel |
Production
| Aluminum |
| Speed* (Mild steel) |
Optimum quality |
12 mm (1/2") 2540 mm/m (100 ipm) |
| Cut angle | ISO 9013 range** |
5 |
| Weldability | Preparation required |
| Process gases by material (Plasma/shield) |
Mild steel Stainless steel Aluminum |
O2/H20 N2/H20 N2/H20 |
| Process amps | Not all processes available for all materials |
260-760 beveling (all) |
* Note: Take care in comparison: competitors often show maximum cutting speeds rather than speeds that deliver the best cuts, as shown above. Cut speeds listed above deliver best cut quality, but cut speeds can be up to 50% faster.
** ISO 9013 is a standard that defines cut quality of thermally cut parts. The lower the range (range 1 is the lowest), the smaller the angle on the cut face. Cut angle in range 4 is better than in range 5.
HT4001 with Slave Mechanized Torch Standard Consumables
HT4001 with Slave Mechanized Torch Bevel Consumables
Highest productivity The HT4001 is designed for 100% duty cycle at 80 kw output to give you maximum uptime. Longer parts life means less downtime for nozzle consumable replacement and more cutting time. Superior system reliability ensures that the HT4001 will be running when you need it. The HT4001 delivers excellent cut speed. For example, at 340 amps you'll cut 110 inches (2.8 m) of 1/2-inch (12 mm) mild steel per minute - with virtually no clean-up needed. |
Lower costs
Hypertherm's patented LongLife parts
technology greatly extends the life of
consumables while using oxygen,
yielding impressive cost savings.
Superior cut quality means minimal
clean-up. That reduces your labor
costs and makes your operation
more efficient. Maximum flexibility Available power of 260 or 340 amps for oxygen cutting and up to 760 amps for nitrogen cutting. You can add a slave power supply at any time to provide output current up to 760 amps. This extends the cutting range of your HT4001 to 3-inch (75 mm) stainless steel or aluminum. Superior cut quality 340-amp oxygen capability delivers dross free cuts up to 1-1/4 inch (32 mm) thick at 90, approximately 3/4-inch at 45 bevel. Oxygen plasma is the optimal choice for cutting mild steel. It eliminates dross across a wide cut range. You get faster cut speeds at lower power levels. Oxygen plasma improves weldability of the cut face because it virtually eliminates nitriding on mild steel. Cut edge surfaces are exceptionally smooth. Using nitrogen, the HT4001 delivers 400 amps of power to slice cleanly through 2 inches (50 mm) of stainless steel or aluminum. |
- Manuais do Operador (Não disponível)
- Não disponível
- Videos
- Plasma vs. Oxyfuel (46 MB) Assista ao vídeo
- Ferramentas de Vendas do Sistema (Não disponível)
- Não disponível
- Ferramentas de Vendas de Consumíveis (Não disponível)
- Não disponível
- Estórias do cliente (Não disponível)
- Não disponível
- Novidades de produtos (Não disponível)
- Não disponível
- Fotos (Não disponível)
- Não disponível
- Logotipos (Não disponível)
- Não disponível
- Anúncios (Não disponível)
- Não disponível
- Serviço de informação (Não disponível)
- Não disponível
